Thumbdrive
If I wanted to use a different thumb drive and ordered one off amazon. Would it work or would I have to have some files on the thumbdrive for it to operate with the Plantix?
Hello! A new thumb drive will work, whether it’s empty or already contains previous projects. Just make sure it has enough available space to store the new project.
We recommend using a SanDisk Ultra Flair 16GB drive.
HI Ashley - Thanks for the response. I was hoping that would be that case. Thanks again!
I might add that you purchase several thumb drives to have as back ups. I have learned over the years to carry it back up of not only cameras, but thumb drives and SD cards.
That was what I had in mind. Just wasnt sure if it had a to have some sort of files on the drive for it to work. I hear you about back sd cards. Made that mistake once!
