If I want to use the Z one for creating panoramic images in other platforms… Do I have to disconnect the Z one from the Iguide? Or can I use the stand and I guide set up but bypass the eye guide platform?
You can use it standalone while attached but you’ll need to ensure that the WiFi is turned on as it’s not turned on by default when the iGuide is on.
However, you can use it through the Survey app as normal and then use the “h1.jpg” images that are created for your panos.
Thank you! Very helpful.
