Hello.
Is there a maximum size for an iGuide? I may have the opportunity to photograph sports centres etc. That means more than 3,000 square metres.
I also wonder if the system can handle the height of the rooms?
Thank you.
Hello.
Thank you.
The system doesn’t measure heights, so that should not matter. We have shot buildings of up to 100,000 sq. feet with no problem. This has included open areas such as warehouses and smaller areas such as apartment buildings. Give Planitar up to a week to process the data, however.
You can just manually laser the height of the roof and add it to stitch in post.
What would be the reason to want ceiling heights?
It’s important to include height measurements in warehouses because it affects the amount of vertical storage and machinery that can be installed.
