Is there a way to disable a pano after the Iguide Has been created?
I have a couple of open closet doors I forgot to disable before the guide was sent to the drafters. Can I disable the pano (s) in front of the open closets? I created a second pano nearby with closed closets that I would like to only use.
Brad
Yes, click on edit for the tour you want to work with.
Scroll down where you see the preview of the tour.
double click on the pano in the floor plan map. when you double click it, the circle will turn red, click save on the bottom and it wont show in the tour. You can reverse it by doing the same.
