Iguide Report Contains the wrong house and Floor Plan
Has anyone gotten an Iguide report back and the panos/floor plan are the wrong property? They’ve put the correct address on the PDF and Virtual Tour, but the panos and floor plan are of a different house that I did a couple of years ago. I just double checked that the TAR file that was submitted is correct. I opened a support ticket but it doesn’t look like they will get back with me until tomorrow. Just wanted to see if anyone else has had this issue come up?
Yikes - never heard of that before. Sorry can’t help.
That mismatch between the PDF address and the actual panos is the part that would worry me most, since the paperwork looks right while the visuals point elsewhere. Good that you verified the TAR file before opening the ticket, that rules out a submission error on your end. The fact it pulled a property from a couple of years back sounds like an indexing or account-history problem rather than a simple upload glitch. I have not run into this myself, but I would keep the confirmation number handy and ask support to check which job ID the panos were tied to.
I’ve had something similar happen. Once only - so far. It was a measure only - no tour. I don’t remember right now if the address was correct or not, but the floor plan was not a property I had done, ever. I opened a ticket and they got it sorted out. Good luck to you!
The sketch mismatch is odd enough on its own, but pulling a plan from a property you never did, as the other poster described, points more toward a job-ID mixup than a bad upload. The TAR file being clean before you opened the ticket is worth mentioning to support so they don’t go chasing a submission error. Ask them which job ID the panos and the sketch were both tied to, since that would show whether the plan came from a different account history or was generated in error.
Hi Robbie,
Thanks for raising this. After reviewing the project with you through Support, we were pleased to confirm that everything was processed correctly on our end from the Stitch data we received. Because of the way our system processes and stores each project’s data, it’s very unlikely for one property’s data to end up in another iGuide. That said, we take reports like this seriously and would always want to know if it ever happened.
If anyone sees something that doesn’t look right in their iGuide, please open a Support ticket so our team can review the project data and find the cause as quickly as possible.
Have a great day!
