When I use the planitar ‘app’ and start scanning, if I want to stop and align a single scan manually, I cannot seem to get back to the view where I can see the 3D photo and the scan as well. I also cannot get back to just the 3D photo itself, nor switch back and forth between scan data and 3D photo.
Is there a button or setting that allows swapping the UI while scanning/shooting?
Thanks for the time stamp and info. When I press that button it goes between scan mode and a messed up version of the split screen, no photo view mode. Changing from portrait to landscape doesn’t adjust it.
You can see in the screenshot below the red arrow points to where the photo view mode is stuck at the top of the screen.
A handful of times in last couple of years I’ve run into the browser not behaving as expected. The solution has been to force-close the browser (not just minimize and reopen).
If you’ve only tried this on your iPad and you get the same result with different browsers, then the next logical troubleshooting step is trying a different device.
Try it on your phone and, if you have access to both an iPhone and Android phone or other Android device, try it on those as well.
Agreed.
Something is confounding the results, since the rest of us using iOS devices aren’t having this problem. I suspect a device setting is the culprit, perhaps a font setting or other somewhat obscure option that the rest of us aren’t using. I’ve seen that happen when choosing extra large fonts on a device, for instance. Not everything plays nicely.
Hopefully by opening a support ticket the issue is identified and resolved.
Oddly, despite never had this problem, I experienced it today when doing a job with an iPad. Earlier in the day I didn’t have a problem with my Android phone.
I use a Samsung tablet. I tried using my phone in the very beginning and I had issues. But with the tablet it made it so much easier and turning it into portrait view I was able to see so much more.
