Forgot To Set Floor Level
I scanned an entire single story home as the 1st floor and forgot to change the floor to basement when I went down. Is there a way to correct this without having to go back out and scan again?
Yes. No probs. In Stitch right-click on “Main Building” and create a new floor. Drag all of those panos to the new floor.
FYI: You can also create a new building by right-clicking the property address and “Create new building”. I often create “Outbuildings” and then drag the detatched garage, shop, barn into that category to separate it from the home.
In stitch create a new floor then drag the pans from the main floor to that basement. Make sure to set the level to below grade.
