External buildings
My apologies if this has already been asked but I can’t find any threads for it in the forum.
A lot of the houses I photograph are comprised of the main house and then either large seperate garages or seperate offices and by seperate I mean standing alone some 20-30mtrs apart. Is there a way to scan these out lying buildings as well? If there is I’m obviously missing it. Thank you in advance.
Add a floor and scan away. Once in Stitch you can right-click on the project name and “add building”. I usually create one called “outbuildings”. Drag and drop the “floor” you created down into the new building and, voila!
For outbuildings, I recommend adding to your notes “Please di NOT exclude interior area of out-buildings.” The drafters are used to excluding garage interior areas and seem to do the so for shops, barns, etc.
Thank you so much. I have a lot to learn about this system.
