Could we add bleed and crops to the Feature Sheet Creator? I have a number of clients who use the feature sheet creator and are having issues when it comes to printers not wanting to accepting the PDF feature sheet without bleed edges and crop marks. Its not if it can be printed but the quality once trimmed and folded. ‘Setting up your file properly for print (bleed and crops) will give you a more consistent and predictable product, with a higher end look. When the file is missing bleed and crops you can end up with things becoming uneven and inconsistent from one page to the next, within the same order’ Hopefully this is an easy fix. Many thanks
