The latest tech updated (Technical Update 031 - March, 2022) points out that each view can be assigned which viewer should be used and refers to a “system default”.
Tech support confirmed that operators can’t change the default – only on a per-view basis. It sounds like it’s something that only Planitar can change on a default level.
Unlike the screenshot they shared in the tech bulletin, the default is the new viewer.
