change location of circles on floorplan with aerial panos
I’ve made a few tours recently with aerial panos and aligned the panos in stitch where I wanted them.
the problem is that the circles to go from the aerial view back into the house are way off on other houses. how can I adjust those?
thanks in advance.
tom
When you place the aerial Panoramas into the User Pano, you have to zoom completely into the green location dot until you see a pie in the circle, then you turn and align the green line with the main structure in the image. That way the Halos of the other Panos will be in the correct location.
