I had an idea while I was mapping a property.
Larger Trigger Button
Larger [+1] Buttons
[Manage Feature Option]: End of Process Beep
[Manage Feature Option]: Expert Mode (automatically creates a new pano per shoot + triggers the panoramic photos in succession)
[Survey Feature Option]: Default display of the Coverage when finished a shot.
[Survey Feature]: Dynamic HDR Control.
Backstory:
I managed to get a free Amazon Fire Kindle from some vacation deal. Yet another piece of electronics to keep charged; years ago I started thinking about my charging station and the countless types of batteries and device types that need to be kept alive. I started to honorably (and dishonorably) discharge electronic devices based on their net worth in my life, the Kindle Fire was up for review.
Since I already have a highly functional Samsung Galaxy Tablet to use for my mobile office and presentations (I was also using it for the IMS-5 app), I really didnāt need or want another tablet. More batteries⦠Selling it online would be a waste of time since you can get them new for 30$ online, a pawnshop might give me 10 for it.
It is lightweight, small enough to fit inside the IMS-5 Roadcase (my Galaxy is huge), and it has WiFi capabilities⦠Could I use it specifically for the iGUIDE Camera APP?
The idea that I could reassign the Survey Duty from my Galaxy to the Fire was a good idea. My Galaxy is my mobile office and presentation tool, I certainly didnāt want it getting knocked around doing iGUIDE surveys (it happens); Iād much rather keep the Galaxy Tablet shiny and strong for presentations and mobile office duty.
Well, the Fireās WiFi and the weak Amazon Web Browser both connected to the IMS-5 just like a smartphone, only bigger! On its trial date, I used a lanyard to keep it around my neck (the same way I used my Galaxy), and it didnāt swing around as much and was much lighter, it also performed just fine. Okay then - it gets to have a purpose now. It now lives with the camera in the roadcase.
I sling the device around my neck & shoulder to keep it in position to use for iGUIDE surveys, screen facing out so all I need to do (once the project is setup) is take a peek at the screen and hit the shoot button.
I thought that the shoot button could be much larger, making it easier to just tap the corner of the screen to take a shot instead of having to tap the small button with precision. It actually adds an extra 2 seconds for every shot.
I also streamline my workflow by not using the [+1] on the main screen since the app will automatically ask me to add or replace a shot anyway. Well, that button is even smaller, so it adds another second, since Iām already looking at the screen, to add another pano. BTW, It would be great if the warning pop-up beeped to let you know something isnāt normal. If that [+1] button on the warning pop-up was as big as the new shoot button, thatād be awesome! If it positioned itself over the same location as the shoot button, thatād be amazing! I would only have to do the corner tap twice and not even have to look at the screen to do itā¦
Time and time again, Iām looking at the screen waiting for the Processing Images dialog to finish. Thereās no beep when its done. If it would beep when its done, I wouldnāt have to stand there staring at the screen every time (looking like I donāt know my hardware), waiting for it to be ready. Itd be a nice feature, especially for instances where processing takes extra time.
I then thought of my process.
- Setup camera in position for a shot.
- Make sure the camera is in a shooting position.
- I make sure Iām out of the way.
- I hit the shoot button, then hit the [+1].
- I count the clicks, then rotate the camera to position #2.
- I then wait for the Processing to finish, and repeat 2 more times from Step 2.
Letās say you have a tight workflow and you spend a lot of time staring at the device screen, tapping tapping and rotating gear, dancing out of the way over and over again⦠Iām sure youād have it down to a science after your 3rd property.
What if there was an expert mode for those of us that move and dance like cats? A mode that takes over at Step 4.
Turn on the Expert Mode:
- I hit the shoot button, the APP automatically creates a NEW PANO and proceeds to shoot.
- The camera clicks, then I rotate the camera to the next position and dance out of the way.
- Once the camera is ready for shot #2, the app automatically executes shot #2; I repeat Step 5 once, the app does its thing again and beeps to let me know its done the series.
It would reduce the number of times an operator would have to look at the screen and tap the shoot and [+1] buttons.
A good scan is important. Itās another slightly complicated step to review the coverage of each shot (to make sure you have solid data) when youāre done a set. It would be stellar if there was an option to display the coverage automatically on scan shots. No more revisiting a property because of "Overlapping Data " - youāll get to see and correct it on location! Obviously for snapshots or shots without the laser wouldnāt review the coverage.
PLEASE, donāt take away the Snapshot feature!!! I use it to test my HDR settings! Speaking of thatā¦
Setting the HDR settings would be SO MUCH EASIER if the upper right HDR Settings Readout was DYNAMIC⦠That is, touch it and you get a dialog that allows you to change your HDR settings. The HDR Options on the Survey Page could then be removed to add space for something else or just clean up the screen. Having to adjust the HDR in the MANAGE Page is like driving back and forth over a speed bump several times to get the right setting for a shoot.
Okay : Just some feature observations for a better, stronger future!
Cheers!
