Anyone here in Alberta that I can pick your brain about a duplex and condo?
I’m trying to figure out the measurements for 1/2 a duplex and a couple of condos and how to enter that into the iGuide when there are common walls.
My realtor says the condo’s are paint to paint but I wasn’t sure they fall into apartment style or not since they are one level senior homes.
If you have not had a chance to explore this, be sure to check out Residential Measurement Standard | RECA
From the January 2024 tech update (download the tech update here):
One notable change includes the addition of a new principle:
“For semi-detached and townhouse properties, measure the property using the exterior wall at the foundation. If the thickness of the demising wall(s) cannot be determined the thickness of an exterior wall shall be used.”
If you would like more information and clarification about the changes made, I encourage you to direct your questions to the Real Estate Council of Alberta.
I hope this helps!
I already had that information but thank you. I clarified some info with someone else.
Glad you were able to get clarification on this!
Have a great day!
hi
so its just like detached house ?
Just like a detached house, yup. Do your standard wall thickness measurement at the front or back door, and make that the wall thickness for that floor.
The only exception to this rule now, is if it’s an apartment-building type condo. All others, semi-detached, duplex, triplex, townhouse, etc., are all like a detached house.
Just purchased the camera! Do we need to input wall thickness?
Absolutely, if you’re in Alberta. Elsewhere, I don’t know.
so what we do for wall thickness for apartments?
Apartment type properties are to show interior measurements only, so enter the wall thickness in the iGuide as 0 (zero). Only interior measurement will be shown.
Hi. What should I fill the wall thickness space in the iguide software if it is a condo ? Can I put 0 ? Inch
You can definitely enter 0 for a wall thickness. The only caveat is that it has to be an ‘apartment style’ condo to exclude the exterior wall measurements. A townhouse condo, a four-plex, anything like that, has to have a wall thickness entered.
